Which is the best ignition system?
Old Dec 28, 2003 | 05:48 PM
hozb817's Avatar
I am having a hard time trying to pick out an ignition system for my LT1. I had it set on the new Crane ignition, but I knew that the MSD ignition has never dissapointed, now I just got the new summit mag and they have a Mallory ignition, the same brand that came on the 69 Yenko. So now I am really unsure. Could you please give me any advise you can. Thanx for your imput!
Old Dec 28, 2003 | 07:12 PM
Chris 94Z A4's Avatar
Arrow
I have a used Accel 300+ ignition system, less coil. If you are interested shoot me an e-mail.
Old Dec 28, 2003 | 07:42 PM
OBE1 95Z28's Avatar
If you're not looking for special features to control future mods (nitrous, blower), then a MSD 6AL is probably the best bang for the buck. The "L" provides a rev limiter (cuts spark) which is safer than the stock PCM rev limiter (cuts fuel). Most of the suppliers of the digital ignition systems (MSD, Crane) have a lot of failures so I believe the circuits are not as durable as the older analog systems. The digital boxes are a must if you need all of the features. I run a Crane box as that's what came with my Vortech blower...it's be replaced (warranty) once. I ran a MSD 6AL for about 50K miles before the blower install that with no issues.
Old Dec 28, 2003 | 10:57 PM
S.J.S.'s Avatar
If your staying NA then I would just use the stock ignition system. Do a search. I was thinking about that when I did my motor a couple months ago and through research found it wasnt worth it.
Old Dec 28, 2003 | 11:47 PM
ATMINF's Avatar
If you are staying stock there is really no need to upgrade your ignition system. But if you are I can say my MSD 6AL has worked great for years. And if you look under the "hood" of most of the racers they run MSD stuff, also is you look at the GM performance parts stuff they sell is just rebadged MSD stuff. Also look at the "upgraded" ignition stuff that Vortech sends with their kits and its MSD, so with all that my 2 cents goes with MSD stuff.
Old Dec 28, 2003 | 11:49 PM
meengreen 94z's Avatar
I have a couple friends that have had problems with the MSD box. I dont know about the other manufacturers.
Old Dec 29, 2003 | 12:13 AM
BottleFed94Z's Avatar
I had a Crane Fireball HI-6 and I though it sucked...lasted about a year. Now I have a Accel 300+ and I love it.
Old Dec 29, 2003 | 01:17 AM
InjectedSS's Avatar
Dude I LOVE my Digital 6. I swear ive had them all. I had the Crane Fireball with timing retard, then I switched to the digital 7 box. Which was a WAY NICE BOX, but it had tooo many features that I didn't use, like the computer software that lets you retard and advance seprate cyl's etc. So now I switched to the digital 6 box and couldn't be happier... It has SOO many nice features such as the Start Retard, WOT Retard, Stage Limiter, Rev Limiter, it's Digital...
Im also using the Blaster HVC Coil that is designed specifically for the digital 6 box.. Both are really nice products and I haven't had ANY problems or complaints
Old Dec 29, 2003 | 04:32 AM
slowpoke96z28's Avatar
I've had no problems with a MSD 6AL and a Nology Coil.
I am anxious to try the digital 6 box with a nology coil this time.
Old Dec 29, 2003 | 05:41 PM
hozb817's Avatar
I am definatly going for a naturally aspirated 10 second car, for now, I will be in the 12's by spring. I want an ignition system to upgrade from stock. Who would want a stock ignition when there are systems like MSD, Crane, and Mallory. Which coil out there is the best??
Old Dec 29, 2003 | 05:48 PM
OBE1 95Z28's Avatar
I ran a MSD coil for about 10K miles and it failed. Switched to a Crane coil and no issues for 25K miles.
Old Dec 29, 2003 | 06:00 PM
FormulaLT1Power's Avatar
I've always heard MSD was the way to go. But I have the stock ignition system. Any of you guys with a MSD wanna sell yours?
Old Dec 29, 2003 | 06:41 PM
RobbyRob's Avatar
Had freinds w/ crane fire ball and thats what it did. MSD is really good. John Lingenfelter swears by the accel 300+ for the 93-97 LT1. He would know better, But sad to say he died on chrismas. The guy known his ****! R.I.P.
Old Dec 29, 2003 | 07:15 PM
bowtieforpower's Avatar
i havent got an ignition yet, but i am definately going to go with the accel. all my friends that have lt1's have the best luck with the accel over any other ignition. i highly recommend the accel to anyone with an lt1!
Old Dec 29, 2003 | 07:21 PM
RobbyRob's Avatar
I have a 300+ and not disapponted.
