best fuel injector cleaner and oil additive ?
i have a 1996 camaro z28 with lt1 . my check engine light came on . i had it checked on cp . code was for multi cylinder misfire . mechanic said it could be from bad gas . suggested lucas fuel injector cleaner . what do you think is the best fuel injector cleaner and oil additive . thanks jay
Clear the code and see if it returns. An occasional misfire code is not unusual. If it happens frequently and you feel a miss, you likely need a tune-up (plugs and wires, at least). Additives aren't good for much, IMHO.
X2 what Shoebox & Maverick said. I use only one additive & that's every oil change I use a bottle of RedLine Fuel Injection cleaner in my gastank ~ my 94 Z has over 180,XXX miles & never a problem ~ same is true for both my LT1 vettes ~ 120,XXX on each. Redline used to be recommended by BMW & GM. Also, you may want to make sure you use good gasoline ~ google "Top Tier Gasoline"
Oil additives are not recommended.
Fuel injector/valve cleaner on the other hand can help. I used to use a Valvoline fuel cleaner, but can't find it anymore. Now I use Techron. I only use it about twice a year though.
Dan
Dan
Jul 4, 2005 05:00 PM
