Best Clutch/short throw shifter
Old Jun 7, 2003 | 02:42 PM
ZZtop's Avatar
I just purchased a 95 Formula with 100,000 miles on the stock clutch. I will need to replace the clutch soon and I was curious as to what is the best clutch on a budget? I plan to eventually do a cam swap so I would like something better than stock, but I do not want something so hard I cant push it, and money is an issue. I was also wondering which short throw shifter yall like the best? Thanks.
Eddie
Old Jun 7, 2003 | 03:26 PM
Pandamonkey's Avatar
You can do a search for this type of thing - and likely get many good threads out of it.
Quick answer though.............don't know about the clutch as that I'm still on the stocker.
I like my B&M Ripper, but you'll find that opinions vary greatly about which is "best".
[Tony the Tiger voice]They're all Grrrreaat![/Tony the Tiger voice]
Good Luck with whatever you decide.
Old Jun 7, 2003 | 04:15 PM
silversupersport's Avatar
i have seen alot of people with Spec clutches, but like pandamonkey said i would do a search, should be lots of info. as far as the shifter goes, most people seem to go with either the B&M ripper or the Pro 5.0. i think they both perform about the same except with the b&m u cant change the shifter length. i have the b&m ripper and love it.
Old Jun 8, 2003 | 07:37 PM
ZZtop's Avatar
I read a lot of good things about the SLP clutch while doing a search, but I plan on doing a cam swap in the future and I dont know if the SLP will hold the added horsepower? Is the SLP good enough for this, or shoud I be looking into a Spec Stage II?
Old Jun 8, 2003 | 08:56 PM
CamaroBoy96Z28's Avatar
I'm in a similar boat. Had to decide on the Spec Stage II or the SLP. SLP is a gamble if you start getting into mods past plain old bolt ons. I'll be going with the Spec unit. The SLP is basically the stock clutch but improved upon. Heard nothing but good things about both clutches but the Spec is rated at 475 hp holding capacity and gives you room to work with. Go with the Spec.
And I like my B&M ripper.
Old Jun 9, 2003 | 01:58 AM
HtownZ's Avatar
B&M ripper shifter. SLP'S bad *** pressure plate and throwout bearing with a Mcleod disc.........best combo for your money!!!!!!
Old Jun 9, 2003 | 03:09 AM
Dmx4ever3's Avatar
I GOT THE B&M BUT I HEARD THE PRO5.0 IS BETTER AND I HAVE THE CENTERFORCE DUAL FRICTION CLUTCH AND IT FEELS LIKE THE STOCK ONE PETEL WISE BUT IT IS THE BEST CLUTCH OUT THERE I THINK I PAID 475 FOR IT SHIPPED TO MY DOOR AND THEY SAY ITS 90% BETTER THEN STOCK
Old Jun 9, 2003 | 06:49 AM
IDOXLR8's Avatar
The best clutch : McLeod Street Twin
Best shifter: Pro 5.0
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
