best cam for a non track street LT1
H/C install shopping list
http://www.cardomain.com/ride/2297151/4
Everything that is different (springs, valves, etc..) is included with the heads.
I selected LE2 heads for my setup based advice I received from Bret.
He said that the LE2 heads are the best bang for the buck and
that he had see seen them make 15-20hp over a LE1 head in the same setups.
That, coupled with the better components.
I went with the LE1HL (high-lift) cam because I didn't want the lope of the LE2 cam, but I wanted a little more than the LE1 offerd.
It's my DD, and it certainly does lope (and turns heads). If you don't like that, stick with the LE1 cam.
I also had Lloyd port my manifold to match the heads, which is optional.
The thin head gaskets gave me a slightly higher compression ratio, which was good for 5-8hp.
That's why I used 7.150" pushrods instead of the standard 7.20"
What happened to the old gasket? (Why did it fail?)
Typically overheating, improper installation, detonation, etc ...
Was there any damage to the heads or block that required machining?
