Best Bang for the Buck Heads
Old Apr 26, 2004 | 08:02 PM
lookingformore's Avatar
In the process of engine re-build.....stock bottom end.....looking into getting my heads upgraded.....and matched with a Comp Cam LT1 cam like the 305 or maybe 306...looking into Hotcam but not liking peoples responses.....need a stage one head to go...What are you guys using out there?.......
Old Apr 26, 2004 | 08:04 PM
fstenuf's Avatar
lt4
Old Apr 26, 2004 | 08:05 PM
fstenuf's Avatar
i hear Loyd Elliot(sp ) also makes very nice heads!
Old Apr 26, 2004 | 08:35 PM
696redZ-28's Avatar
from what I read I'm sending my heads to Loydd! if you do a search the was agreat post about 7 pgs on head work lots of good info.
Old Apr 26, 2004 | 08:38 PM
97Z-M6's Avatar
lt4s are not worth the money. get intouch with loyd get your heads and cam from him i think its 1300 or 1400 buck for ported heads (you send your heads) new spring locks and titanium retainers and a custom ground cam. you cant find heads alone for that price any where. and on his heads and cam (he has 3 different cams) people have hit upper 420s. ON STOCK PORTED HEADS.
SEEMS LIKE A NO BRAINER TO ME.
Old Apr 26, 2004 | 08:50 PM
ok
What is a sight to get info for these heads
Old Apr 26, 2004 | 09:02 PM
RE AND CHERYL's Avatar
If your talking about Loyds heads. He is a site member and you can PM him, his user name is NIGHTTRAIN66. If you just want him to port your heads and don't want the cam it's like $700-800. You can't beat that anywhere. He also has some cams for his heads ground by Joe Overton. Joe is the s**t! A little pricey, but no body better in my mind.
Old Apr 26, 2004 | 09:28 PM
crzhrs's Avatar
How about the trick flow heads? Fully assembled $1295 seems like a good deal to me.
Old Apr 26, 2004 | 10:28 PM
97Z-M6's Avatar
YES BUT THE RUNNER SIZE IS THE SAME AS STOCK CASTING.
Old Apr 26, 2004 | 10:54 PM
crzhrs's Avatar
Trick flow has 195 intake runners and stock has 175. Correct me if I'm wrong.
Old Apr 26, 2004 | 11:46 PM
1982z28with18s's Avatar
Go with Lloyds heads AND CAM. It's a matched setup and will put down way better numbers than if you just throw parts together. I'm running Lloyds best heads, but a cam thats smaller than all 3 that he offers(but it was matched to the heads just like his cams are) and I ran 11.84 on stock bottem end at a crappy track.
Old Apr 26, 2004 | 11:48 PM
screamin94Z's Avatar
that's what i hear. and they flow like a MOTHA. perfect for anything with a power adder or a stroker setup.
Old Apr 27, 2004 | 06:37 AM
IDOXLR8's Avatar
You also may want to contact Phil at Advanced Induction. He is a sponsor on this forum and very knowledgeable.
Old Apr 27, 2004 | 08:37 AM
ZDriver96's Avatar
Phil and Llyod no doubt.
Old Apr 27, 2004 | 09:21 AM
ASRoff's Avatar
What If I want the thicker deck for N2O? is Loyd as good porting aftermarket heads?
