Best $2500 I can spend on a 96 Z
Car is a 94 A4 with the 3.23 rear gears. And has an unkown 3 inch exaust from the manifolds back and a K&N FIPK, it will also have 17x9.5 AFS Grand Sport wheels with 275 tires. LMK What is the best thing I can do to it to gain more performance. I dont really care about handling right now so looking more for stuff to do to the motor. Oh yes and it will have to pass emmissions something besides bolt on is acceptable. Thanks
get a cam that will pass emmisions like the lt4 hot cam. roller rockers and new valve springs. The lt4 hot cam kit will cover this. about $500 Get a pair of headers with 1 3/4 primaries atleast $300 but plan on spending more. get your heads ported. About a grand. buy a 52mm throttle body or a 58mm. $100 to $300. get your pcm programed $200. new gaskets about $125. 3 inch cut out $150. do the work your self and have about 350 rwhp.
there are programs that can make your car pass emmisions with a bigger cam. there is a free program on brent's site to do this.
Sorry to ask a question in your post, but i have a 96 Z and i plan on running long tubes with hi flow cats. I am looking at carsound cats on ebay right now, just to make sure, i do need the 3 inch inlet and outlet ones, correct?
Thanks,
Bill
p.s. what is this 'airtube' that is an option to run to my cat. do i need this?
Thanks,
Bill
Thanks,
Bill
Thanks,
Bill
All4Chevy: well the stock exaust is something like 2.75 inches i think. a 3inch cat will work. it can be welded on.
2FNFAST: also to keep your motor cooler and to avoid your stock waterpump from leaking on your distributor (they do when they break) get an electric waterpump about 150 plus gain about 10 more rwhp from it. you may also want a stall convertor of atleast 2500 rpm stock is 1500. but when you do that you will need a drag tire because there is no way you will be getting traction.
Put that 2500 towards a built 4L60E. Or you can get LT's, and put the rest away for a built tranny. Reason I say this is if you got even a hot cam kit, the best shift range for those is a bit over 6100, which will promtly kill your stock tranny. And especially if you were to do the cam swap yourself, total cost for the hotcam kit or another cam kit and stage II ported heads would be close to $1000, maybe a little higher. Just something to consider.
Jason
Jason
E-mail Lloyd Elliott at NightTrain66@msn.com
$1200 covers porting the heads, Ferrea 2.00/1.56 valves, Comp 987 springs, 10 degree retainers, locks, locators, seals, machining for seals and locators, milling, cleaning and assembly.
$400 for just porting
$200 valve job, surface, seals, cleaning and assembly
If you need him to supply the valves add. . . .
$200 for REV or Manley
$240 for Ferrera
Hope this helps!
$240 for Ferrera
Hope this helps!
Originally posted by madwolf
Hotcam kit
Midlength headers (AS&M)
Higher stall (2600-2800)
Gears (3.73)
Cutout
High flow cat (check out ebay. carsound for like $35 new)
Tuning
Hotcam kit
Gears (3.73)
Cutout
Tuning
$240 for Ferrera
Hope this helps!
$240 for Ferrera
Hope this helps!
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
Devinfoote87
Jul 30, 2015 09:54 AM
