bent a rod!!(pics) any ideas
Old Jul 12, 2007 | 06:21 PM
dangalla's Avatar
Question bent a rod!!(pics) any ideas
ok about a week ago i left a bar i was at and started my car, immidiatly on start-up a load knocking started, had no choice so i just drove it home(half an hour!!!) and to work to pull the motor(15 mins)
pulled the motor and found this
any ideas what may have caused this
it was raining really hard while i was inside but not when i started the car, i was thinkin maybe a stuck open injector
and i am really suprised the rod bent like that and did not break, especially after driving it so long after it bent
Old Jul 12, 2007 | 07:44 PM
wrd1972's Avatar
Wow.
Has the engine ever sucked up water, this can hyappen cause water will not comnpress so the rod bends. Stuck injector or too much fuel should not do that.
Are you stock or do you have big HP?
Do you have an aftermarket CAI?
Old Jul 12, 2007 | 07:49 PM
dangalla's Avatar
sorry i forgot to post this the only mods to the car is a magnaflow catback
i was thinkin a stuck open injector filling the cylinder with fuel while i was inside and bending the rod on start up because that will not compress
on a side note from stock to 355 le2 is not proving to be cheap but im hoping to have it back on the road in a couple weeks
Old Jul 12, 2007 | 10:16 PM
Just about had to have been water or fuel in the cylinder. There should have been a noticeable "bump" in the rotation of the engine with the starter the first time it was cranked around.
Old Jul 12, 2007 | 10:24 PM
mdacton's Avatar
Your lucky it didn't break
Old Jul 12, 2007 | 10:25 PM
cnorton's Avatar
I disassembled a very low mileage LT1 a few years ago that had the twin to that rod. There was no indication of water in the cylinder so I hypothesized that the cylinder had filled with fuel. All the other cylinders were pristine.
dangalla's Avatar
didnt really notice a bump, bit i did hear the first knock as it was cranking, i tried to let off but it was already too late, the car started and was knocking like crazy
Old Jul 12, 2007 | 10:27 PM
user 647483's Avatar
Wow
Old Jul 12, 2007 | 11:56 PM
SS RRR's Avatar
Do you have a CAI into the fender? Did you notice whether or not you were parked in a puddle? Have you tested the injector to see if it leaks? Were all of your wits about you when you came out of the bar?
Old Jul 13, 2007 | 06:00 AM
itzkwik's Avatar
bad head gasket leaking antifreeze into cylinder?
Old Jul 13, 2007 | 09:36 AM
SevenStars's Avatar
Same thing happened to the guy I bought my z from, he started it and immidately got a knock. One of the rods looked just like yours but a lil more pretzled, my and my engine builder tested out the fuel injectors and 2 were stuck open so we are assuming that was to blame.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BPS
9
Mar 5, 2015 10:51 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
