Bent K-member.
Bent K-member.
My kmember is bent. The collision shop said its not bad so i could probably take it off and straighten it my self. I also have some other bent stuff on the passanger side that i am replacing. I havent looked at my kmember much yet but do you need to take off the a arms to get it off? once i get it off, how can i straighten it? My uncle said i could use a hammer if its barely bent or i could get it red hot and make it straitht.
BTW, my hood, when closed, doesnt align correctly. Could straightening the kmember fix this problem?
Re: Bent K-member.
I wouldn't mess around trying to straighten a bent K-member. Do yourself a favor and just get a new BMR K-member:
http://www.bmrfabrication.com/F-bodyChassis.htm
Re: Bent K-member.
And if you heat it, you'll destroy the integrity of the metal unless it's done right.
I think Josh-'97 WS6 has the right idea. You might want to pick up sub frame connectors too. could help with the hood problem if thats what caused it
CARiD
Sep 30, 2015 05:44 AM
detroitmuscle
Jul 31, 2015 04:21 AM
