Bent crank!! What to do?? 383 stroker??
Old Mar 27, 2005 | 11:56 PM
si's Avatar
si
I know your wondering how I bent the crank. The car decided to do a little ditch running. My intercooler got pushed up in to the supercharger pulley that is on the end of the crank.
I did not know the crank was bent till I fixed the car and had it put all back together. I bought a new supercharger pulley and harmonic balancer and the stub that goes on to the crank. Now I have to yank the motor and put a new crank in. (didn't think the crank would bend)
My question is do I make it a 383 stroker? (No matter what Im going to put forged rods and crank in.) The motor was just rebuilt with forged pistons and reconditioned rods. Im running a P600 procharger kit with 8 pounds of boost, stock heads that are ported and polished and a LT4 kit ( intake, hot cam, roller...) I also have jet hot LT, spec 3 clutch and a moser 12 bolt. I would like to run 12 pounds of boost after I put the new forged parts in, and some good head gaskets. Thanks for your 2 cents!!
Old Mar 28, 2005 | 12:06 AM
SStrokerAce's Avatar
Re: Bent crank!! What to do?? 383 stroker??
It's going to be harder to get the higher boost on a bigger cube motor, plus you should change the rest of the parts to work with the stroker. The cubes are nice but more than just a increase in displacement is needed to get the most out of it.
Bret
Old Mar 28, 2005 | 12:12 AM
1racerdude's Avatar
Get the shaft streightened.There are people who do that and can do it right.If it's a stock crank it wouldn't be worth it but a forged or billet,yea.
Old Mar 28, 2005 | 07:41 PM
si's Avatar
si
Ive been reading some other post, do I have to get the block machined for clearincing for the stroker crank and the rods??
Old Mar 28, 2005 | 07:54 PM
Pasky's Avatar
Believe thats only if you go H beam rods or 6" rods. Not sure. Also believe you need to clearance for a 396, not a 383. I could be wrong.
Old Mar 28, 2005 | 09:05 PM
1racerdude's Avatar
383 will have to be clearanced,how much will depend on your rod choice.
Old Mar 28, 2005 | 09:31 PM
Yeah even have to clearance a 355 if you use L19 rod bolts.... yeah fun stuff.
Bret
Old Mar 30, 2005 | 09:47 AM
si's Avatar
si
Question Re: Bent crank!! What to do?? 383 stroker??
Where can I find the best kit for my money. Any one got any web pages?? I need one asap.
Old Mar 30, 2005 | 10:01 AM
Pasky's Avatar
cnc-motorsports.com has the best deals.
Old Mar 30, 2005 | 10:57 AM
1-bad-z28's Avatar
how did that hotcam kit work with the SC? I am putting my hotcam kit on my 355 with a supercharger and was wondering how it worked out. I know it is not ideal but it will have to work till i get some better heads and cam
Drtryder
Apr 22, 2015 04:17 PM
Rde Bandit
Mar 21, 2015 10:17 PM
maybe2fast
Mar 13, 2015 11:48 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
