Bell housing bolt removal
Old Jan 10, 2010 | 12:02 PM
96redhotz's Avatar
Does anyone have any tips to remove the top left bell housing bolt? I can't get a wrench or a socket on the bolt. The tranny is out, but this is the last bolt to remove the bell housing? Any help would be greatly appreciated!!
Old Jan 10, 2010 | 01:00 PM
RamAir95TA's Avatar
On an auto, you need a super-long extension (I think I used at least a 3 footer) with a wobbler. I would assume an M6 housing will be similar.
Be resourceful and use as many extensions/wobbles/universal joints as possible.
Old Jan 10, 2010 | 01:52 PM
MikeGyver's Avatar
Long extension, pivot the trans down so u can get to it.
Old Jan 10, 2010 | 01:58 PM
96redhotz's Avatar
The tranny is already out and the engine is as low as it will go. The bolt is still in a position that I can't get a socket on. No room in between the tunnel. I thought about using a hammer and a long pry bar and banging the tunnel alittle to make room for the socket an to back out the bolt.
Old Jan 10, 2010 | 02:03 PM
RamAir95TA's Avatar
Plenty of guys on this forum have removed their transmissions. You need to find the right combination of tools, whether it's a thin-wall socket or whatever, there's a way to get it out.
Can you post a picture maybe?
Old Jan 10, 2010 | 02:19 PM
JAKEJR's Avatar
Yep. Long 3/8" extension or several cobbled together, a 9/16" swivel socket, or a regular socket backed up with a swivel.
On your back under the car, feet forward, good lighting. A couple of stacked 2"x4"s as a pillow, patience; BINGO!
Jake
Old Jan 10, 2010 | 03:02 PM
Kevin Blown 95 TA's Avatar
Once you do get it out there will be scratch marks on the tunnel as a testimony to your struggle. It doesn't hurt to smash that in a little bit to make reassembly easier and subsequent disassembly for next time you puke the tranny or clutch.
Old Jan 10, 2010 | 03:10 PM
1965GP's Avatar
this definitely sucks, but like everyone else said- long extensions and patience.
Old Jan 11, 2010 | 06:36 AM
koolaid_kid's Avatar
You might try a wobble extension instead of a wobble socket. It can go in tighter locations a bit easier.
http://www.harborfreight.com/cpi/cta...emnumber=67065
Not recommending the brand, but this is what they look like.
Old Jan 11, 2010 | 10:17 AM
Z28SORR's Avatar
http://buy1.snapon.com/catalog/item....re&dir=catalog
These type sockets with a long extention also work great!! If you use any "flex" sockets or adapters putting some black electrical tape around the flex part will help keep it "in line".
Old Jan 11, 2010 | 11:31 AM
JAKEJR's Avatar
Excellent tip, I forgot to mention it. I do the tape trick too. It gives better control over the wobbling socket.
Jake
Old Jan 11, 2010 | 04:37 PM
SnakeOiler's Avatar
I don't know about a deep swivel, such as the link above provides, but my shallow swivel works great.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
