BBK throttle body
Old Sep 4, 2005 | 09:15 PM
93camaroLT1's Avatar
BBK throttle body
I bought a BBK 58mm throttle used off here, and it is a 94-97 throttle body for my 93, only difference seems to be that I can't hook up my idle air controller(IAC) to it cuz the harness's are completly different, is there a way to make this work? I was thinking, what if I were to just pull a 94-97 IAC harness of a 94-97 Z28 from a junkyard and cut my current harness off and splice in that one.. would that work? If not what do I have to do to use this throttle body on my 93 Z28??
Old Sep 4, 2005 | 11:49 PM
aggiez28's Avatar
Re: BBK throttle body
click here, this tells ya how to use it on your 93
Old Sep 5, 2005 | 03:42 AM
thats great man... now can someone here tell me how to hook up my IAC harness to this throttle body that knows how to or has done it??
Old Sep 5, 2005 | 10:30 AM
93black-ta's Avatar
just curious but do you have an a4 or manual. i know the 93's have the 4l60 and the 94 and ups have the 4l60e so theres an issue with the kickdown.
id be interested in you findings though seeing as how used throttle bodys off 94 and up are more accessable than the 92 and 93's. and i'll be in search of a throttle body soon, mines an auto. im pretty sure ive seen where it has been done though.
i think aggiez28 thinks a 93 is a 3rd gen???
Old Sep 5, 2005 | 11:06 AM
vin1382's Avatar
Sorry to hijack, but I have a 93 also and just picked up a bigger throttle body. I am an auto...I figured that since mine isnt electronically controlled, i wouldnt have a problem with the tranny shift points as it shouldnt be affected at all...is that what you were saying in your post??
can anyone confirm?? I just had my shift points changed in my 93..and it was a PIA!! I'd hate to have to do it again.
Old Sep 5, 2005 | 12:00 PM
93black-ta's Avatar
the 93 throttle bodys have a provision for the tv cable and the 94+ do not.
so there is an issue there but im sure it can be converted to work.
Old Sep 5, 2005 | 12:53 PM
Fastbird93's Avatar
The IAC harness on the 94+ is a flat 4 pin harness, and on the 93's is a square 4 pin harness.
You'll either have to:
A: Purchase a 94+ IAC pigtail for the car harness and cut your 93 harness off and splice in the 94+ pigtail. To do this right, you'll have to have wiring diagrams for both, and match up the wires correctly.
or
B: Use your old IAC housing and IAC that came off your car and simply put them in the new TB. Should bolt right up. No splicing necessary.
www.speeddensity.org -- it's been covered a few times over there.
Old Sep 5, 2005 | 01:07 PM
aggiez28's Avatar
no i know a 93 is a 4th gen.
he just posted this in advanced tech, when it should be in lt1 tech. figured he may need a refresher on what belongs in advanced tech
brook
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
warmeck
May 1, 2015 11:30 AM
lt1-xjs
Jan 17, 2015 07:52 PM
