BBK throttle body
Old Jul 16, 2003 | 08:07 PM
bobs's Avatar
BBK throttle body
Hey everyone,
I just installed a 58 mm BBK throttle body on my 95 Trans Am, and I can't get the tube that connects the robber hose from the mass air sensor to the throttle body to fit around the new larger throttle body. I tried to make it fit, but it's leaking air Is there an aftermarket tube I can buy that will fit? Has anyone else had this problem? Or know how to fix it?
Thanks.
Old Jul 16, 2003 | 08:08 PM
REPO's Avatar
Your stock one will fit, you just have to be carful. I found sparying the inside of the rubber elbow with a bit of WD40 helps 100% in slipping it on.
Old Jul 16, 2003 | 08:22 PM
OrangeAndWhite's Avatar
You can always get a Vortech elbow or a TrickFlow elbow, they can be found on summit. They are both ceramic coated for a clean look, and the trick flows come with orange rubbers.
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
warmeck
May 1, 2015 11:30 AM
lt1-xjs
Jan 17, 2015 07:52 PM
