BBK 58mm TB question
Old Feb 8, 2005 | 06:07 PM
whatsup's Avatar
Did a search couldn't find info I was looking for. Does anyone know for sure when boring out the intake for a BBK 58mm TB, are the openings on center? It would be no problem if I had intake and TB in the same place but they are about 300 miles apart at the moment and I'm getting the intake machined here. Thanks!!
Old Feb 9, 2005 | 06:47 AM
whatsup's Avatar
Re: BBK 58mm TB question
Someone's gotta know.......
Old Feb 9, 2005 | 07:06 AM
Geoff Chadwick's Avatar
I'll be home around 6:30pm Eastern Time tonight, if nobody has your answer by then I'll whip out the calipers and let you know.
I'm pretty sure they're on center though, but I'll check tonight.
Old Feb 9, 2005 | 08:47 AM
whatsup's Avatar
Thanks really appreciate it!!
Old Feb 9, 2005 | 10:34 AM
ajschult's Avatar
Try this: http://www.bfranker.badz28.com/96ss/58porting.htm
Old Feb 9, 2005 | 10:55 AM
whatsup's Avatar
Thanks...good to hear from a fellow Iowan...
Old Feb 9, 2005 | 11:06 AM
Z95m6's Avatar
The BBK is dead center. I believe the AS&M is offset at least that is what Brent told me. I had my intake off and wanted to port it to 58mm size just incase i went to a 58mm TB later. I just used a caliper and opened the bores 5mm all the way around. When i finally got my BBK TB it matched up perfect.
Old Feb 9, 2005 | 04:03 PM
whatsup's Avatar
Thanks...that's what I was looking for!!!
Old Feb 9, 2005 | 04:34 PM
med_reject's Avatar
my bbk was not centered at all.
Old Feb 17, 2005 | 04:49 PM
whatsup's Avatar
Just for future reference the BBK matches up perfect if you enlarge on center. Mine is sitting here looking good.
Peytons'z
May 6, 2021 09:25 AM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
Mike Meyers
Aug 14, 2002 01:26 PM
Mike Meyers
Jul 25, 2002 07:35 AM
