Battery Issue: Need Help ASAP
Old Sep 20, 2006 | 12:19 PM
EviLBoX's Avatar
I just went out and put my key in the ignition, car had power, then turned the key and everything went completely dead. I can't even lock/unlock the doors. I popped the hood and checked my battery connections and everything looked okay, so I just jiggled the wires a little bit and once again the car had power. I turned on my headlights and they're bright as usual, no sign of a dying battery. I put my key in the ignition and the radio works, but as soon as I turn the key everything goes completely dead. Any ideas on what might be wrong? Otherwise I'm stuck at work today The battery is only 2 months old.
Old Sep 20, 2006 | 12:35 PM
snod83's Avatar
Re: Battery Issue: Need Help ASAP
Check the connections, then check them again. Sometimes the added draw to the battery will cause a weak connection to become no connection. Also, check the terminals themselves. I had mine corrode and come off at one point......
Good luck.
Ryan
Old Sep 20, 2006 | 12:41 PM
FuryZ28's Avatar
Check the positive terminal post. I'm not talking about the one on the battery, but rather GM's poor excuse for a power distribution block. It should have a small cable that sprouts from your positive battery wire to the post, and on top of that is the most/all the accessories, including the ignition. I don't know exactly how, but my Camaro managed to MELT that post, and was causing everything to ground out on the body. Once I bought a REAL power distribution block from Advance Auto (the only kind they sell is fused, which isn't necessarily a bad thing...) and connected the wiring to the necessary posts, the car started and ran fine. Still does...
Old Sep 20, 2006 | 12:58 PM
mcssmostwanted's Avatar
im having the same problem myself but all my wires are ok.... and im stuck as well... good luck man
Old Sep 20, 2006 | 02:18 PM
If your headlights go dim or out when you turn the key, it's probably a loose connection. If they stay bright, it may be the ignition switch.
Old Sep 20, 2006 | 02:52 PM
97WS6SCharged's Avatar
Check the cables/battery for corrosion.
Old Sep 20, 2006 | 03:29 PM
EviLBoX's Avatar
I went ahead and disconnected both terminal connections and retightened them, the car starts fine now. I guess it was a bad connection on the terminal. Thanks guys.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
