battery or alt?
Old May 22, 2009 | 06:52 AM
jay_rich's Avatar
battery or alt?
Okay, I just got done my turbo swap and the car was running fine, alt was charging BC at first I had a small charge wire and it melted tryin to charge the battery. So I put a 4awg wire for the charge wire.
Now all of a sudden I am dumping in my 2 bar tune (after the car ran for 10min) and the pcm gets fried bc the battery got to low.
So I jump start the car (I had anoter PCM) and the car runs for like 15 seconds then dies.
So I decided to charge the battery, left it for a couple hours and come home and the car runs for like 2 minutes then dies.
The battery is 3 years old and has lost charge about 3 times in the last 2 months (do to running the car no alt and checking all my wiring etc )
Also the battery is only like a 600CC amp battery, I always wanted to buy a new optima or something but didn’t wanna waste money.
So could it be the battery isn’t holding charge and I chould get a new one? I would suspect alt but it just seems weird bc the alt has been rebuilt and only has like 10-15KM on it.
Jay
Old May 22, 2009 | 07:26 AM
DAVE00's Avatar
Take both the alt and the battery to your local autoparts store and have em' checked as they can tell you if the battery is bad and not holding a charge as well as if the alt is not putting out the correct amp or volt.
Old May 22, 2009 | 08:48 AM
USAFretired's Avatar
If you have a meter you could put the meter on the battery and see the voltage then start it and see if it goes up. If the voltage does not go up I would say its the Alt. That's how I check it anyway.
Old May 22, 2009 | 04:26 PM
jay_rich's Avatar
OKay so I charged the battery and it was around 12.05V after a few starts. I remade the wires at the starter and they seem good.
Now I start the car and the voltage doesnt go to the normal 13.5-14.5V.
If i take the alt wire off the battery should there be voltage there?
Jay
Old May 26, 2009 | 10:40 AM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
sounds like an alternator problem. i agree with dave i work at an autozone just take it to them and they could check both things
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
WPHIG2
Aug 27, 2015 06:37 AM
