Basic rebuild, whats needed?
Old Dec 8, 2006 | 03:07 PM
69gto96z's Avatar
I am wanting to do a basic bottom end rebuild on my car when I do my cam. The motor runs great, has excellent oil pressure, but at 130k miles I am afraid of spinning a bearing with a high revving cam. Could I reuse my stock pistons, rods, crank, and just rehone the cylinder walls, put new rings/bearings in, and put it back together? I am not going to be pushin enough power to need to go forged, so I figured this would be fine. Also, I will get my crank polished while its out. Any input would be great. I am planning on either a CC306 or LE2 set-up btw.
Old Dec 8, 2006 | 03:18 PM
street demon2k3's Avatar
if i was going that route i'd go at least with some new Hyper. pistons along with a new ring set at least. then do bearings and polish the crank like you mentioned. even though you wont be pushing a lot of power i would spring for some speed pro pistons which are fairly cheap but give a little peace of mind. a friend of mine went with a speed pro piston and ring kit with his rebuild, along with a cc306 and ported heads + 175 shot of juice and ran a 10.7@126. prolly coulda gone faster but he blew the rear-end out of the 60ft. lost of potential for a setup like that.
Old Dec 8, 2006 | 03:34 PM
MeanGreen97Z's Avatar
6 speed car or automatic?
Old Dec 8, 2006 | 03:36 PM
69gto96z's Avatar
Awesome, thanks for the info. Where can I get those pistons from? I figure if I pull my motor apart and can still see the cross-hatching in my cylinder walls, than just re-honing it and having new bearing/rings and possibly pistons out it would be fine for what I want to do.
Old Dec 8, 2006 | 04:50 PM
94Camaro_Z_28's Avatar
Yup, all I did was have mine honed. Pulled it apart at 140,000 and the crosshatch was still there. No sludge....Mobil 1 =
I had my block cleaned and all that good stuff, new cam bearings installed, honed the cylinders and replaced the main/rod bearings. Thats it.
Old Dec 9, 2006 | 01:10 AM
69gto96z's Avatar
Awesome, hopefully mine will still be in good shape. I run 4 quarts of valvoline max life 10 w40 and 1 quart of rislone. My dad runs the same in his car, he opened up a 20 year old motor last winter and it was as clean as could be. Idk what was used in my car before but hopefully its clean.
Old Dec 9, 2006 | 02:40 PM
transAMdriv3r's Avatar
when i did my rebuild i got speed pro pistons 8 of them for 160. dealer wanted that much for 1 of them. pm me and ill tell ya where i got them if your interested. I dont think i can say on here where i got them cause that would be advertising.
Old Dec 9, 2006 | 05:43 PM
Daniel6718's Avatar
you could get pistons if you want...but rings bearing honing and hot tank is necessary....call me or txt i can get a deal and help put it back together
Old Dec 10, 2006 | 12:43 AM
69gto96z's Avatar
Awesome Daniel, ill let you know when I am getting closer to doing it. It wont be until summertime most likely before I have the cash put back to do everything I wanna do.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
