Barebones cam swap...
Old Sep 8, 2008 | 12:17 AM
LSWHO's Avatar
What is the absolute limit to the fewest things needed for a cam swap assuming a stock engine?
Would a valvespring upgrade be basically it?
I KNOW YOU WOULD GET NOWHERE NEAR THE NORMAL AMOUNT OF POWER OUT OF A CHOKED CRAPPY SETUP LIKE THIS.
I am talking with a friend about this and want outsiders opinions.
I just want to know the absolute limit to run an aftermarket cam.
Old Sep 8, 2008 | 01:46 AM
henryz28's Avatar
What size cam. For a big cam you will need a lot of work. For something like the hot cam you can get away with just springs and timing chain.
Old Sep 8, 2008 | 10:11 AM
slomarao's Avatar
+1 on springs and a timing chain.
Old Sep 8, 2008 | 10:15 AM
LSWHO's Avatar
Large cam, but stock redline.
Old Sep 8, 2008 | 10:48 AM
Stl94LT1's Avatar
If he is keeping the stock redline, I wouldn't go to wild on the camshaft.
Old Sep 8, 2008 | 11:41 AM
<Puck>'s Avatar
Very bad idea.
Old Sep 8, 2008 | 12:08 PM
95ltslow's Avatar
Do it once and do it right the first time.
Old Sep 8, 2008 | 07:28 PM
LSWHO's Avatar
Yes, thanks for the advice. I know what to do, the question is what is the absolute basic LIMIT needed to run it.
If I were to run one, I'd do RRs, 10308 kit, GM guideplates and chromeoly pushrods, LTs, gears, stall, probably some heads and still keep the shift at or below 6500 until I could build a bottom end.
Old Sep 9, 2008 | 08:21 PM
LSWHO's Avatar
So, nobody can elaborate on why a big cam needs more work done? I can see more work to optimize it, but nobody can explain why a big cam would require more install necessities?
Old Sep 9, 2008 | 08:37 PM
2000GTP's Avatar
The bigger the cam, the harder it is going to be on the other valvetrain parts. You slap a big cam into a stock engine and fail to upgrade any of the valvetrain components, you are probably going to break something.
Old Sep 9, 2008 | 09:01 PM
Red-LT1's Avatar
Not to mention it will put your peak HP into a range where your stock heads will choke it, all the while losing some low end torque.
Old Sep 9, 2008 | 09:27 PM
LSWHO's Avatar
Break what?
This has no bearing on the question at hand.
Old Sep 9, 2008 | 09:40 PM
dubbsix's Avatar
I think the point made about you breaking something DOES have a bearing on your topic because its good advice that might save you the trouble and money of doing it over right the first time.
Plus what good is going through a cam swap, but the increased HP is beyong the range of your other components?
I am currently doing a cam swap on my 95 TA. I bought a cc503 cam, comp camps magnum 1.6 RR, new push rods and timing chain. I also have a set of factory ported castings with a fresh valve job and a set of pacesetter headers.
Im on a budget (as everone might know on this board lol), but sometimes it just pays dividends to listen and do the job right.
Old Sep 9, 2008 | 09:52 PM
LSWHO's Avatar
I never said it didn't. I said hp range has absolutely nothing to do with my question.
Which components? I keep asking this. Still no answer.
So you are running stock springs? I can tell you that is the biggest mistake you can make.
I've heard of people running stock pushrods on a CC306, so that's not necessary in all applications either.
Basically what you are saying is that headers are the only necessary mod for a cam, which I can tell you are NOT necessary. For peak power, yes. But NOT necessary.
Old Sep 9, 2008 | 09:56 PM
LSWHO's Avatar
I'm not trying to be rude here. I'm just trying to elicit an answer but nobody is answering I keep getting the same old "you won't make the power you want." Or "you need to rev it higher," or "you need ported heads." But my question has nothing to do with this.
Pretend I am trying to make the worlds SLOWEST over cammed F-body.
I am simply looking for what is Required to do a cam swap.
