Bare essential gaskets for cam swap
Old Apr 2, 2005 | 08:16 PM
Dwaynez28's Avatar
Question Bare essential gaskets for cam swap
I just want to do just a cam only swap, I see Thunderracing has a kit for around $100--Dont think i need all that--What gaskets/seal do i really need for just my cam swap only? Intake manifold, water pump shaft seal, opti gasket, crank seal and timing cover gasket--Im sure i missed something, thanks for your help, suggestions-- Dwayne
Old Apr 2, 2005 | 08:50 PM
Re: Bare essential gaskets for cam swap
Gaskets you will destroy:
Intake manifold
water pump (2)
timing cover
Others you may need:
Valve cover gaskets
all the round seals in the timing cover
Water Pump O-rings
Opti-spark O-rings
Oil Pan gasket
Old Apr 2, 2005 | 10:23 PM
Dwaynez28's Avatar
Thanks for your help Dwayne
Old Apr 2, 2005 | 11:29 PM
Alvin@pcmforless.com's Avatar
Get a front cover set from felpro.. You'll be surpized what they are throwing in there now.. oil pan seal, opti and water pump drive stuff.. even water pump gaskets
Old Apr 2, 2005 | 11:32 PM
Dwaynez28's Avatar
Again Thanks for the help Dwayne
Old Apr 2, 2005 | 11:36 PM
Dwaynez28's Avatar
Hey Rooster if all goes well you,ll be get my pcm someday Dwayne
chuyz28
Feb 19, 2015 12:50 AM
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
