balancer/hub together?
Old Nov 27, 2006 | 11:44 AM
jeepbeast's Avatar
i tried searching, didnt find anything, soo
wondering if i could just pull both the hub and balancer together? it seems as if i could just leave the three balancer bolts connected to the hub and pull on the inner part of the balancer and have it all come out as one? i know that i would have to pull the balacner center bolt. any way this would work? or am i just trying to make something too easy than it really is?
thanks....
Old Nov 27, 2006 | 12:26 PM
Will84's Avatar
yes, yes, no
I pulled it with the pulley/balancer bolted to the hub.
Old Nov 27, 2006 | 06:01 PM
jeepbeast's Avatar
what i have is a 3 claw puller, i plan on attaching it to the balancer, putting a 1/4 inch extension into the hole of the crank bolt (to center puller), making sure the extension is long enough so i can push against the rear of crank bolt hole and crank the crap out of it.
any other ideas how i can use the claw puller to get both of them out together?
Old Nov 27, 2006 | 06:50 PM
If you were to pull them together, I would use a convetional balancer puller (a crow's foot puller-not a claw puller).
Old Nov 28, 2006 | 08:24 AM
WS Sick's Avatar
I wouldnt pull onthe outer part of the balancer, if you notice there is a rubber ring between the center part of it and its outer ring, if it pulls apart the balancer is ruined.
xdeified
Dec 5, 2011 10:46 AM
Gio93z
Jun 19, 2011 07:07 PM
ddr698
Jan 13, 2011 10:51 PM
ddr698
Nov 29, 2010 07:03 PM
Camaro_Maniac63
Mar 28, 2008 07:16 PM
