balancer ?
Old Apr 10, 2003 | 09:22 PM
CamaroRob97's Avatar
balancer ?
hey guys im doin a timing cover, oil pan gasket under drive pulley and electric WP upgrade and i was wonder is there any special way or trick to get the balancer off? i got the haynes book and it says the balancer itself shoulld come off by undoing the three bolts, then u het a crank puley puller to remove the hub, but i can't even get the balancer to come off. also i was wondering to remove the oilpan im gunna have to hoist the engine slightly won't I?
Thanks!!
Rob
Old Apr 10, 2003 | 09:43 PM
viperkiller's Avatar
the pully is the hub or balancer all the same thing
pull out the bolt in the center of the pulley then with a puller pull the pully off and i warn you to be careful with the pully puller becouse you can ruin your crank
Old Apr 12, 2003 | 01:48 PM
no man the book says the balancer/crank pulley comes off, then u use a pulley puller to take the hub out., does anyone else know anything about taking the crankpulley/balancer off?
Old Apr 12, 2003 | 02:03 PM
larson_lars64's Avatar
I would have to say that the pulley might come off when you take those 3 bolts off. But if there is any way you could ever get a balancer off without a puller i would love to know about that. You need a puller to pull the balancer, they are on there tight. And viper is right, you can wreck the crank if your not careful. So watch where you put the puller end.
Old Apr 12, 2003 | 02:48 PM
anaik's Avatar
Here's how to take the damper off.
http://csce.uark.edu/~jgbertr/rb/pull_pulley.jpg
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
