Bahhh car wont start
Old May 7, 2005 | 12:09 PM
aintno6's Avatar
Well went to work, car was fine. On the way back, car was fine. Then I went to go out later, and the car would not fire up. I was like wtf. Its turning over, has correct voltage, but it just keeps on tryong to turn over but it wont. I check my scanmaster for any DTC's, and there are none.
Well it just so happens I have my buddys fuel pressure tester. Before I put it on I let the remaining fuel out of the fuel line/rail. And some fuel comes out, but not alot. So then I hook up the tester. i have my bro try to crank it over... 0! DOAH! So I call my buddy Todd, he recommends I check the voltage on the fuel prime wire thats near the pcm. Well I may need to get a better connetion on there to test it. But when I goto turn the car on (not crank), you would normally hear the fuel pump wine or buzz from the rear of the car. Well I didnt hear that. But the voltage meter jumped to 5. So my guess is the fuel pump is dead. I'm going to check the relays and fuses just in case though. I'm also going to check the voltage on the fuel pump prime wire again.
But my question is. What fuel pump do you guys recommend. And who has the best price on it?
Mike
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
teedoff59
Aug 8, 2002 01:36 AM
