Bad waterpump cause hard starting?
Old Jun 18, 2005 | 02:52 PM
Tair's Avatar
Like the topic states...would having a bad waterpump cause my car to take longer to start than normal? I have a definite leak coming from the weep hole of my waterpump, so I am changing it out, but I just wanted to know if changing my waterpump might cure this situation. I am also getting a strange sound coming from under the hood. It sounds similar to the air-sucking sound that new air filter intakes make, but louder. The sound changes according to RPM.
Old Jun 18, 2005 | 02:57 PM
BLinindoll's Avatar
Re: Bad waterpump cause hard starting?
mine made that noise and it was a clogged cat. opti may be about to **** the bed sence its getting wet from the water pump.
Old Jun 18, 2005 | 05:24 PM
Tair's Avatar
any other comments on my situation? I've used the search feature and surprisingly not much turned up about this...
Old Jun 19, 2005 | 07:47 AM
The water pump is not going to cause hard starting unless it is getting your opti wet. If it was you would probably have other symptoms after it started up.
Old Jun 20, 2005 | 01:12 AM
Dave '97 Z28 M6's Avatar
When I had a WP leak, it did make the car had to start (wet opti). But like shoebox said, I experienced several other symptoms, including wild fluctuations in readings on the temp gauge, and the car would run like crap after starting (due to the wet opti).
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
