bad vibration in steering wheel
Old Nov 28, 2003 | 07:04 PM
ticket_me_redz's Avatar
My car has a bad vibration in the steering wheel when I'm driving. Tires are rotated, balanced, and front end aligned every 3 to 5K. Tires still good. Seems to do it more when I'm going straight. Not as bad when I turn the wheel slightly like in a curve. Also seems really bad between about 45-65. I've had a passenger in the car when it was happening and they commented on how bad the steering wheel vibrated. So I know its bad when a passenger can see it shaking. Any ideas?
Thanks.
Oh, 82,xxx on the car.
Old Nov 29, 2003 | 10:01 AM
lastlaf's Avatar
If your wheels are balanced and are not out of round, and the alignment is ok then I would check to see if your front rotors are warped.
Old Nov 29, 2003 | 10:08 AM
thermwood1's Avatar
Another possibility could be a bad wheel bearing.
Old Nov 29, 2003 | 10:18 AM
jchevy's Avatar
When was the last time the tires were balanced? An old weight could have fallen off. You could also have a tire begining to seperate. If i were you i would take it to a tire shop and have them balanced. Ask them to take a close look b/c you are getting a bad vibration.
You do not want a tire to blow out which will happen if it is separated. When they blow a lot of times they take the fender with them. It can do a lot of damage to the side of the car.
If its not in the tires next place i would look is wheel bearings.
Old Nov 29, 2003 | 10:31 AM
HBHRacing's Avatar
sounds liek a wheel bearing especialy of it goes away when you turn the wheel and load that bearning. are there any noises?
if not that it sounds like a wheel/tire ballence issue.
you shouod also check you tie rod ends and ball joints. jack teh front up and grab the sides of the tire and move it back and forth and look for play. there should be NO movment in the tie rod ends and none to very very little in the ball joints
Old Nov 29, 2003 | 10:35 AM
Thanks for the replies. I guess its been about 2 months since the last alignment, rotation, and balance. The thing with that is that even when I do get all that done, as soon as I get in the car it will drive like a dream up till 45-50 and then the vibration comes back from 50/55-60/65. I'll let the place that I take it to know I get a bad vibration around the mph and see what they say. I'll jack it up and see if I can notice anything. I dont hear any noise that is noticeable, however, every now and then the front right will make a clinking noise when I hit a whole. Thanks again for the replies.
Old Feb 27, 2004 | 07:29 AM
licerio's Avatar
Hey man, I'm having exactly same thing,, did you find anything out? thanks
Old Feb 27, 2004 | 08:40 AM
Bow94z's Avatar
are tie rods and wheel bearing expensive at a dealer
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Airplanedoc
Feb 1, 2015 07:14 PM
mattszm6
Dec 14, 2014 07:09 AM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
