bad vibration
Old May 9, 2007 | 03:36 PM
seawolf06's Avatar
bad vibration
I thought it was just the poly mounts (driver's side motor and tranny) at first, but after a friend rode with me he said no way they could do that.
You can't really feel it at idle. If I rev it in neutral at a stop, it's hardly noticible.I can feel it at part throttle accel, but it's REALLY bad when I'm decelerating in gear or "engine braking".
It happens whether the clutch is engaged or not as long as the RPM are up, and we're moving. Usually gets bad above 2k or so.
I don't really feel it when I'm going WOT, but I am concentrating on a lot of other things.
I had the rotating assembly balanced with the flywheel and the balancer. I can see where they drilled into the balancer and I guess they put weights on the flywheel.
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
