Bad valve guides cause this?
Old Jul 26, 2004 | 09:57 AM
Gripenfelter's Avatar
Would bad valve guides or seals cause you to blow the dipstick out and blue smoke from the exhaust?
Old Jul 26, 2004 | 10:02 AM
944v8inDFW's Avatar
Re: Bad valve guides cause this?
Not likely, blue smoke yes, dipstick out no. Sounds like you got a major compression leak. Bad rings, hole in a piston ect. Maybe bad adjustment on valves. Blue smoke usually indicates oil burning as i am sure you know. You may want to do a comprression test or leak down test.
Old Jul 26, 2004 | 10:39 AM
Thanx for the quick reply.
I knew that oil could leak through into the cylinders but wasn't sure it pressure would go the opposite way.
Do you have to pull the heads to change the guides?
Old Jul 26, 2004 | 10:44 AM
944v8inDFW's Avatar
Normaly on valve guides you need to take the heads to a machine shop. The valve seals can be changed ing the car PITA but can be done. My concern is pressure in the crankcase to blow the dipstick out. I would still do a compresson on leakdown test before pulling the heads.
Old Jul 26, 2004 | 11:11 AM
Ok thanx.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
Roadie
Feb 16, 2015 10:34 AM
LT4Ryan
Jul 29, 2002 08:38 PM
