Bad top end knock
Old Sep 16, 2004 | 03:33 PM
stik6shift93's Avatar
Bad top end knock
I just swapped in a newer set of lifters for my car out of an ls1, the ls1 was running great before they were pulled. When i put them into my car and fired it up i got a horrible knock, I adjusted everything accordingly and set the rockers to 3/8 turn preload. Does anybody think that one of the lifters is collapsed? Also to check for a collapsed lifter do i get the lifter onto the base circle of the cam and push on the pushrod to see if it goes down?
Old Sep 19, 2004 | 05:36 PM
Re: Bad top end knock
ttt
Old Sep 19, 2004 | 07:34 PM
Mtrhds94Z's Avatar
Do LS1 and LT1 lifters interchange?
I never heard of that..
I don't know much about LS1 motors tho..
Old Sep 19, 2004 | 11:19 PM
blwnlt4's Avatar
it would sound like to me the valves need to be re-adjusted, did you adjusted them once when engine cold/ then when the engines hot
Old Sep 19, 2004 | 11:59 PM
Yes the lifters are about the only thing the lt1 and ls1 have in common. I just readjusted everything and after putting the a wrench on the crank to turn it over to get the other valves i noticed at tdc #1 it doesn't want to turn over, and i have to use the started so i think there's something stuck in the motor . Is there anyway to tell if you dropped a valve?
Gtpguy
Jan 26, 2015 04:50 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
