bad starter
Old Feb 1, 2016 | 02:46 PM
black96camar's Avatar
bad starter
When crank my car over now, even with a full charged battery, it just barely turns the motor. And starts smelling like burning wires. Is there a way to test if it's bad
Old Feb 1, 2016 | 03:18 PM
Re: bad starter
You can remove the starter and have it tested at most auto supply stores. First thing is to make sure all your cables are clean and tight.
Old Feb 1, 2016 | 04:15 PM
Re: bad starter
Thanks I'll try that
Old Feb 2, 2016 | 01:32 PM
blac94Z's Avatar
Re: bad starter
Sounds like the ignition switch if your smelling buring wires from under dash
Old Feb 2, 2016 | 02:46 PM
Re: bad starter
It under neath the car from starter
Old Feb 2, 2016 | 04:22 PM
blac94Z's Avatar
Re: bad starter
well like shoebox said verify the cables are clean and tight and are not burned
Old Feb 2, 2016 | 07:21 PM
bw_hunter's Avatar
Re: bad starter
It's often hard to see but the cables can be corroded on the inside, between the strands, raising the resistance. These cars are getting pretty old now and very few people actually change out the battery cables...
Maroz28maro
Jul 29, 2016 07:45 PM
chevyowner02
Aug 8, 2015 01:38 PM
pimpinphil
May 30, 2015 04:20 PM
