Is this a bad plug/wire?
Old Apr 29, 2009 | 04:07 PM
Camm95Z28's Avatar
Hello, My question when driving my Z, I need to really nurse the clutch in first gear as it has no low end power, then it once moving, it sputters and backfires while driving. Also the SES light comes on after about 5 minutes of driving. Once I let off the pedal, the backfiring is quite loud.
Question is this a bad plug or plug wire?
Coil or Opti?
Thanks in advanced.
Old Apr 29, 2009 | 04:20 PM
JooneJune's Avatar
Have you scanned the SES light for a code?
Old Apr 29, 2009 | 04:51 PM
Camm95Z28's Avatar
That I havn't as this has just started .
I drove it recently for 10 miles and the SES didn;t come on at all. Power is still way down and sputters, backfires, so forth.
Old Apr 29, 2009 | 07:09 PM
bw_hunter's Avatar
Will it rev cleanly and smoothly to redline in neutral?
Old Apr 30, 2009 | 03:54 PM
Camm95Z28's Avatar
Yes it revs fine. While driving it runs kinda rough below 2,000 RPM. I have to feather the clutch out to make sure it has power. Once above 2,000 it runs descent, can still hear some sputtering and backfiring. It doesn;t run well enough to use 6th gear though. Also notice the shifter shaking at times.
Old Apr 30, 2009 | 08:31 PM
itSSlowZ28's Avatar
sounds like a burnt wire or fouled plug to me. does the car have aftermarket headers? if so its pretty likely you burnt a wire
Old Apr 30, 2009 | 10:55 PM
96LT1TX's Avatar
burnt wire. The stutter under 2,000 RPM is a dead give away (in my experience) to a burnt plug wire. As it gets worse, the car might start almost 'bucking' until you get to 2,000 RPMs.
Old May 1, 2009 | 11:21 PM
Camm95Z28's Avatar
The lone pertinant mod is a Borla cat back. This makes the backfires that occur while it's driving fun since it sounds like I am being shot at from behind .
Thanks for the input. I was glad to hear it was a plug. I have owned this Z since 98 and in it's career it has had 7 Opti's
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
