Bad optispark?. Leaking water pump
Old Aug 13, 2013 | 03:46 PM
Capnmike95's Avatar
1994 z28 a4 I've had the car sputter under load and does it when warmed up. I've changed spark plugs, I had a hole in my intake elbow so I have a new cold air intake. The water pump has the fluid dryed up on the seams and may have leaked on my opti. To cause the car to run like s#*!, never had an lt1 only own an ls1 so need help ASAP. It's hesatiates around 1000-2000rpm. Just don't know where to go from this one.
Old Aug 15, 2013 | 11:06 AM
Capnmike95's Avatar
Re: Bad optispark?. Leaking water pump
Anyone?
Old Aug 15, 2013 | 03:52 PM
slick1hunting's Avatar
may want to give the opti connections a look ror corrosion. Might be worth spacing the icm and coil off head(shoebox has instructions for that). May also be time to check codes and datalog. Checking fuel pressure cant hurt either(but not my guess). Thats all I could offer up. Good luck.
Posted from Camaroz28.com App for Android
Old Aug 15, 2013 | 03:53 PM
May also be worth checking it out in the dark looking for arcing.
Old Aug 21, 2013 | 07:58 PM
boomtufo's Avatar
If your water pump is leaking change it and the opti at the same time.
That's what I'm currently doing and am now waiting for an opti to ship in, wish someone would've told meto buy a new opti with the pump.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
