Bad news...tonight I find out what happened.
Old Nov 5, 2007 | 07:53 AM
CANTONRACER's Avatar
I have been fighting a high rpm issue for years so late last week I swapped out the stock opti (which was completely destroyed internally) with an Accel unit and get my t-brake hooked up.
So Saturday I am buttoning the car up...fire it up to start bleeding the coolant system. The car was on jack stands in the front and I knew that my vacuum pump had pulled some oil.
I took a look at the gauges for the first minute when I fired up the car and everything looked fine, but after 10 minutes of idling the motor seized.
The only thing I can think it being is an oil pump shaft broke or I simply ran the motor out of oil.
So tonight I pull the engine and see what happened and the extent of the damage...which I am hoping is just a crank turning and bearings.
If this happened this time next year, I would be ok with it because I would be getting ready for my twin turbo on, but I plan on running the car for a season learning the F.A.S.T. system.
I am kicking myself in the **** if it was something as simple as checking oil...if that is it, I will just have to remember that putting vacuum pump and the reservoir in the wrong direction is a no no.
Well, at least I can fix a few things that I did not like.
Old Nov 5, 2007 | 08:50 AM
97s10ondubs's Avatar
sucks man, hope everything works out for you, now you get to make changes
Old Nov 5, 2007 | 09:04 AM
Javier97Z28's Avatar
Moderator
Sorry to hear man
Old Nov 5, 2007 | 10:41 AM
MEAN LT1's Avatar
Sorry to hear about that man. Dont get to caught up in the "while the motor is out I might as well do this". That tends extend the down time of projects.
Old Nov 5, 2007 | 08:00 PM
Ends up the motor was not seized...the CSR starter seized so hard it stopped me from turning the motor with everything I had.
Pulled it out and presto...motors turns by hand just fine.
Old Nov 5, 2007 | 08:18 PM
HottestZ28's Avatar
that sucks
a rebuild is cheaper/easier then a starter
Old Nov 5, 2007 | 08:24 PM
That is AWESOME, good thing you caught that, would have been an expensive mistake.
Old Nov 5, 2007 | 08:26 PM
ABA383's Avatar
You really lucked out...Thats awesome!!
--Alan
Old Nov 6, 2007 | 09:33 AM
T/A lt1's Avatar
I'm glad to hear it was the starter b/c when I read the first post I was depressed for you. I just put mine back together and man i would be pissed if it locked up. Good luckk Clint
Old Nov 6, 2007 | 09:37 AM
Dave1980's Avatar
Wow that rocks! Talk about an emotional rollercoaster.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
captcorvette
Mar 7, 2015 12:37 PM
Briah.hood
Feb 17, 2015 02:10 PM
BMX Dad
Jan 23, 2015 07:00 PM
