BAD miss
BAD miss
Alright if i start up my car and begin to drive it will be fine until it reaches a certain temp. then it will begin to miss and hesitate badly. it is very bad at idle when setting at a light or "trying" to take off from a light. seems that the longer it idles the worse it will get. while driving if it does this i can rev it up a couple times and it will clear up and be fine. when i shut it off after driving for a good while and restart it after 30 mins to and hour it will also run like total crap. i have been fighting this for sometime now and i'm completely fed up with it. some days it runs fine and others i cant go over 30! i have a 211/219 duration cam and headers other than that its pretty much stock. new plugs, wires, opti, and soloman tune.
Any help is appreciated!
Thanks, Kyle
Thanks, Kyle
Re: BAD miss
If it's heat related, it could be the ICM getting to hot. When the engine is cold, you could heat the ICM up with a hair dryer or heat gun and see if that reproduces the problem. The ICM can also be tested at Autozone, but it will be cold, unless you take it off while it's hot in the parking lot.
Re: BAD miss
If it seems to be water temperature related, it's probably the water temperature sensor in the water pump. The PCM uses that reading to adjust the fueling....richer when cold,etc.
Give it a look......
Re: BAD miss
The sensor is often just cruded up. Try pulling it and cleaning it before buying a new one....
rideordie
May 3, 2015 12:53 AM
