Bad GAS???
Old Oct 10, 2011 | 01:52 PM
94YellowTAGT's Avatar
Bad GAS???
Car was running great until i was running low on fuel. So i filled up with 91 Shell. The next day i noticed the car was spitting and sputtering really bad. Problem seems worse under load. Is this a sign of bad gas? IF so how is the best way to empty the tank?
Thanks,
Old Oct 10, 2011 | 02:13 PM
ShowOff67's Avatar
Re: Bad GAS???
maybe change the fuel filter and see if that works might have a clog
Old Oct 10, 2011 | 02:23 PM
Re: Bad GAS???
That could be. I don't drive the car more than 500 miles a year. Garage queen. But we have been driving it more with the mild weather and i let the gas get lower than normal. Might have picked up some junk from the bottom of the tank.
Old Oct 10, 2011 | 05:44 PM
RamAir95TA's Avatar
Re: Bad GAS???
You could have trashed the fuel pump. What is your fuel pressure?
Old Oct 10, 2011 | 06:18 PM
Feenix's Avatar
Re: Bad GAS???
yeah, coulda burnt the pump up, it uses the fuel in the tank to keep it cool, and they don't like to be ran dry. Check the pressure and make sure thats ok before you empty the tank thinking its bad fuel.
Old Oct 10, 2011 | 06:50 PM
Re: Bad GAS???
I only got down to the 1/8 tank mark. Lower than it has been in years. I wonder about the filter. That will be my first step. Would the pump work at idle but falter under load?
Old Oct 10, 2011 | 07:09 PM
RamAir95TA's Avatar
Re: Bad GAS???
It could do a bunch of different things really. A gauge would be crucial in determining the health of the fuel system.
Old Oct 10, 2011 | 07:12 PM
bw_hunter's Avatar
Re: Bad GAS???
The 1/8th tank mark is pretty much empty.....
z28cam1993
May 29, 2015 10:17 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Amshnock
14
Jan 18, 2015 11:47 AM
blac94Z
Nov 24, 2014 07:12 PM
simple
Aug 11, 2002 11:56 AM
