bad air pump
bad air pump
ses light is on; air fuse under hood(20amp)keeps blowing. This is on a '95T/A(OBD-1). If I unplug connecter at pump and install new fuse will the ses light stay off? For emissions check will my tailpipe emissions go up(without changing pump). Will disconnecting the battery for an instant erase the code from the computer? Lots of questions...lots of THANKS! Larry
Re: bad air pump
Re: bad air pump
Irecently removed mine and took it apart. Motor was fine, but there's a solenoid valve on the outlet that was so corroded, it wouldn't move in its bore. A little PB Blaster and a few cycles by hand and it was fine.
Reassembled, reinstalled, no more blown fuses!
It is a pain to get it apart though.
Re: bad air pump
I remember reading the recall (actually a TSB) on the 95's. I don't remember anything about the wiring.
It basically said that condensation could enter the pump by getting past the check valves. This will cause corrosion of the pump internals and causes the fuse to blow.
The repair was to render the pump inoperable. They capped the inlet and outlet lines and removed the power. They said it wasn't needed anyway.
Here's the link:
http://www.impalassforum.com/tech/en...p/air_pump.htm
I wish I could remove the one on my 94, but I don't think it will pass a visual inspection, which is still required on ODB I cars (in my area anyway).
Here's the link:
stockssn2o
May 25, 2015 08:54 AM
. Cleared up the engine bay quite a bit also.
