is this bad?
ok i was under my car checking out the connections of the plug wires to my opti....my opti is covered in oil...i mean...its not pouring out...but its covered and you can tell...i think this could be the culprit of my hesitation?
what should i do??? i mean im gonna end up changing the opti...but those orings? is that where the oil would be most likely coming?? and would the oil be getting into the opti and if so...would that have the same effects of moister getting in there?? thanx all!
explain please??
ok i havent done a opti yet...so im kinda like what are you talking about....the seal? is this something that i can change when i do the opti? i need more info thanx
Re: explain please??
like i said i got an electric waterpump just so i never have to deal with it again cause its THAT BAD! and even if you do get it in.. chances are it will leak soon enough
Originally posted by speed76demon
well i have oil on my opti to could that cause his hesitation??
how bad?
ok so if i take the wp off and the opti....then the timing cover should be right there....i take that cover off then what? i mean woldnt it be right there? pop it out...put the new one in...waaaala or is it harder than im saying? the way your saying it, itsthat big of a deal? has anyone else donethis???
colts0455
13
Aug 7, 2015 09:15 PM
zajones
Jul 30, 2015 02:18 PM
