Backfiring throught intake
Old Sep 14, 2006 | 08:14 AM
95zsean's Avatar
My car only does this when it is warm and I give it a shot of gas and then another shot getting ready to do a burnout.It never does it any other time!!!Any thoughts would be apperiated.
Old Sep 14, 2006 | 08:45 AM
Bobsep84's Avatar
Re: Backfiring throught intake
Optispark. Also check plug wires, coil and coil wire. I had a problem where it would backfire out the intake and lose all power under WOT. I replaced the opti and found that the coil wire was bad. Once all that was replaced the problem went away.
Old Sep 14, 2006 | 09:47 AM
95zsean's Avatar
I hope its not that because they are $599 in Canada! What I was thinking was the IAC because I have a problem with idleing to hight when you start the car and when I stop at a stop sign.I have already repltaced the center head gasket because it was leeking oil so it's no a vacume leek. It only does this at low idle!!not at WOT. Any more thoughts?
Old Sep 14, 2006 | 01:39 PM
TobyZ28's Avatar
order them from cromer. $260 ish i think US, + shipping + brokerage fees = Way cheaper than 600 ish.
Old Sep 14, 2006 | 06:14 PM
95zsean's Avatar
Thanks can you give me a link or a address for Cromer?
Old Sep 14, 2006 | 06:29 PM
Lower's Avatar
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Sep 14, 2006 | 06:41 PM
95zsean's Avatar
Thanks,So you really think its Opti?? I guess I can save for it over the winter.
Old Sep 14, 2006 | 07:24 PM
1FstFormulaV8's Avatar
Which wire are you referring to? Coil to Opti cable?
andrewcapps82
Jun 2, 2015 10:57 PM
Chet1185
May 10, 2015 09:24 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Drtryder
Apr 22, 2015 04:17 PM
F(ast)-body
Feb 26, 2003 09:05 AM
