backfire at 4000 rpms, help
Old May 4, 2004 | 06:44 PM
ddlouhy127's Avatar
i have a backfire at 4000rpms and up, what could be the problem? im changing plugs and wires this weekend could that fix it?
thanks
Old May 4, 2004 | 07:30 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I have had the same problem twice. One time it was a spark plug wire arcing onto the header and the other time it was my opti going out........... Good luck.
Chris
Old May 4, 2004 | 09:39 PM
camaro325's Avatar
the same type of thing happened to my friends astro van...and his problem was that the coil would open under load, so he replaced the coil and the problem was fixed
Old May 5, 2004 | 10:22 PM
That reminds me. I replaced the coil first and it did HELP but it still did it............ Could go either way. Tryi coil first, then opti.
Old May 5, 2004 | 11:14 PM
med_reject's Avatar
backfire with hesitation (I.e. misfire at high rpm) typically bad plugs. Bad wire makes the car lose power and accelerate really rough, very noticeable at low rpms (assuming 1 wire).
Old May 6, 2004 | 01:30 AM
Maybe a "bad" wire yes. But mine did it because it would arc onto the header. I am assuming it only did it in high rpms because the lunge of the car made the wire move.......... But thats what caused the EXACT same issue on my car so... Check that just in case.
Old May 6, 2004 | 01:40 AM
med_reject's Avatar
ya, i forgot about the arcing bit. How do you test for that?
Old May 6, 2004 | 01:44 AM
Start your car at night and look at the headers from all angles.... I tried to look for it one night and didnt see anything.... But it turns out when i pulled it onto ramps, and looked at the wires from underneath... you could see a blue spark arcing from the #7 wire onto the headers........
Chris
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
