Back fire and studder...
Old Apr 20, 2010 | 08:59 PM
Myxtreme1's Avatar
This has been a problem with my car since I have owned it. Every now and then if you try to punch the throttle real quick, it'll just "POP!!" or back-fire. I have checked the TPS and it checks out fine. Also right around 4500 rpms it almost seems like it is banging the rev limiter. As far as I know there is no rev limiter installed via programming. Any good trouble shooting idea's?
Old Apr 20, 2010 | 11:13 PM
retroj23z28's Avatar
I'm having pretty much the same problem. I've been on forums since I've owned the car, and soon found the Opti-spark is usually to blame with symptoms like this. I have yet to replace my Opti, but this should fix my problems (which are very similar to what your experiencing). This is not to say you couldn't have other ignition/sensor problems, but the distributor is usually a good place to start.
Old Apr 20, 2010 | 11:17 PM
95Blackhawk's Avatar
Can you datalog?
Old Apr 21, 2010 | 08:03 PM
Myxtreme1's Avatar
Originally Posted by 95Blackhawk
Can you datalog?
So far I haven't been ableto get Datamaster to connect correctly. I'm pretty computer savvy but can't seem to get it just right. I have gotten a new laptop so maybe that will be the ticket. Unless something is wrong with my comm port in the car. I put a new opti on the car when I bought it and the condition still existed after that. Needed a new one either way though. It now has at most 14k on it and I've had the car for 7 years.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DetroitZ28
Feb 13, 2015 07:33 AM
Jazsun
Dec 29, 2014 12:14 PM
nophix
Nov 30, 2014 10:26 PM
