Awe crap.. ??? is up with the longer dowel pin?
Old Oct 16, 2008 | 10:26 PM
dubbsix's Avatar
Went to install my cc503 cam tonight and noticed that the dowel pin in the new cam is longer than the OEM cam. Will this work with my 95 Opti?
I Installed the cam..im sure hoping i dont have to pull it out and have the dowel pin changed..
Old Oct 16, 2008 | 10:29 PM
mdacton's Avatar
its just pressed in, tap it in some more
Old Oct 16, 2008 | 10:33 PM
dubbsix's Avatar
Awe good god... I alread installed it into the motor.. im taking its not a good idea to tap on it while its installed right?
I didnt bolt it down so i guess no big deal in taking it out again.. Just dont want to put too much stress on the cam bearings.
Old Oct 16, 2008 | 10:38 PM
Grind it down, but seal off everything so that you don't get filings in there. As much talk as there is about dowel pins, I am very surprised you did not know to check it. The cam install guide on my site specifically warns about this and has a pic.
Old Oct 16, 2008 | 10:43 PM
mdacton's Avatar
don't tap it in the motor you will knock the plug out the back.....
If you bolt the retainer on and the timing gear it will hold it on the front of the block....
but its not a big deal to pull it back out...put on bolt in the timing gear on the cam opposite of the dowel and use that as a handle, pull it back out...no stress, the thing with cams is not to knick the breaings, just don't do that be careful.....
dubbsix's Avatar
Rookie mistake. I guess i didnt do enough research. I dont have a grinder and probably wouldnt do it properly anyhow. Would tapping it in more work?
Old Oct 16, 2008 | 10:53 PM
bombebomb's Avatar
My lunati cams pin was out way to far also, seems to happen more often then not.
Old Oct 16, 2008 | 11:40 PM
dubbsix's Avatar
Yea i'll just slide it back out. Once its out, how do i know the dowel pin will go in any deeper? If its too long can I take it to a machine shop and have them grind it down?
Old Oct 16, 2008 | 11:42 PM
dubbsix's Avatar
Yes but will it work with my opti???
What did you do? Leave it as is? The question i had for everyone was will it work with my 95 opti? If it'll work i dont care how long it is.
Old Oct 16, 2008 | 11:43 PM
bombebomb's Avatar
My engine builder tapped it in.
If you do not tap it in to the same lenght as your stock cam, then it will eat your opti. You have to tap it in, or replace your opti every 10 miles.
Old Oct 17, 2008 | 12:18 AM
brianswimmer23's Avatar
and before you tap it in get something the same length as the stock pin and put it around the pin so you only tap it in that far and not more than you need to.
Old Oct 17, 2008 | 09:03 AM
dubbsix's Avatar
Thanks guys. I'll slide the cam out and tap the pin in.
Old Oct 17, 2008 | 06:47 PM
Don 97 SS's Avatar
.620" is recommended length. I tapped one in as far as she would go once and then had to grind the tip a bit further to get it within specs. Yes, doing this preinstalled a heck of a lot easier. It would make a mess with the shavings.
Old Oct 17, 2008 | 08:21 PM
dubbsix's Avatar
Im gonna remove it and hope i can get it close to the stock length. If not off to the machine shop...
Old Oct 18, 2008 | 03:54 PM
dubbsix's Avatar
Well.. removed the cam and hammer on it a bit and its in as far as its going to go. I guess the next step is to drop it off to a machine shop to either replace the pin or grind it down.. Darn. Well lesson learned.
