Autozone opti?
Old Oct 5, 2008 | 11:10 PM
henryz28's Avatar
Autozone opti?
First I just wanted to say they are junk. I went through five of them in 2 years. Most all of them the car would start to ping. I already got a GM Opti and it has been fine so far. But I do have the Autozone one and was wondering if I could get my money back for this POS. If I am correct they are obligated to give me the money for the price of the opti and the core charge. Has any one else ever returned an Autozone opti for a refund?
Old Oct 6, 2008 | 01:52 AM
Green96Z's Avatar
Strange, I have an Autozone opti with an MSD cap running well over 10k miles now. Could be something else wrong with your car that is killing the opti. Did you use that opti? If you used it I don't think you can get a refund. They will exchange it if you have a warranty on it though.
Old Oct 6, 2008 | 11:22 AM
wrd1972's Avatar
Here is the reason nearly all NON GM optis fail so quick. The NON GM optis have a cheap knock off 360 segment pulse wheel that does not have the segment openings cut out very well. I saw one that had flashing connecting two segments. This confuses the sensor. Also the pulse wheels are warped and make physical contact with the optical sensor and cause it to fail.
If one get the AutoZone opti, inspect it for the things mentioned above. If it does not show these problems, it should work fine. And loctite the damn rotor screws too.
Old Oct 6, 2008 | 10:18 PM
henryz28's Avatar
Took the dam thing back today and got a full refund. I got a opti from the partsladi on ebay for $255 shipped. It is a GM Delphi unit; should I have used locktite on this rotor also?
Old Oct 6, 2008 | 10:31 PM
gatorhead's Avatar
Thats a good opti and yes loctite the rotors regardless of brand.
Old Oct 6, 2008 | 11:44 PM
RallyBoy1's Avatar
I have an Autozone opti right now and it works great! It is probably due to using the original GM segment pulse wheel instead of the wheel that came with the Autozone unit.
Old Oct 8, 2008 | 08:33 AM
popstoy's Avatar
Also check the bearing before installation, a wobbley bearing will rub the disk on the sensor.
Old Oct 8, 2008 | 10:40 AM
wrd1972's Avatar
That is wise to do.
Old Oct 8, 2008 | 01:03 PM
SS44Camaro's Avatar
what did you tell auto zone to get your refund?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
