Auto Tranny Issue
Old Feb 26, 2003 | 10:41 AM
justa25thTA's Avatar
Auto Tranny Issue
94 A4 TA, 86K on it, fluid and filter changed at 80K. When you start it up cold, and put it in gear, it is shifting VERY hard, the 1-2 shift is also VERY hard, this will continue until you restart the car and it is warm, then everything is ok. Checked the fluid and it is full and doesn't smell burnt or anything.
Any ideas? It can't be good for it to be shifting this hard.
Old Feb 26, 2003 | 09:04 PM
kjlvilla's Avatar
Have the PCM scanned for codes. Some will set but not light the Check Engine Light. If a trans. code is set then the PCM may max the line pressure. This will give you harsh park to drive or reverse engagements and most noticeably a harsh 1-2 shift.
Old Feb 26, 2003 | 10:41 PM
Silver Z28's Avatar
mines so harsh that I chirp the tires under normal driving, lol
thx to EvilBox, I'm gonna go flush my fluid and see it that helps
Magenta_Hearts
Mar 29, 2017 08:54 PM
jackpawt883
Feb 26, 2015 09:04 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
tds1213
Nov 27, 2014 12:55 PM
Snoman73
Nov 17, 2014 07:22 PM
