Auto meter Tach, which wires go to what?
Old Mar 28, 2013 | 03:35 PM
96 TA's Avatar
I have an auto meter tach that im going to be installing in my 96 Trans Am, I had it in another LT1 before but i can't remember which color wires from the gauge need to be hooked up to the car to have it work properly. The meter has Black, White, Green and Red wires. The black im assuming goes to a ground, but as for the rest and most of all the the wire that connects to the PCM i have no clue. Can anyone help? Thanks
Old Mar 28, 2013 | 03:46 PM
96 TA's Avatar
Re: Auto meter Tach, which wires go to what?
did some additional searching and from the tach the wires are
Green- to negative side of coil or to tach output on electronic ignition ( im guessing this goes to the input wire from the PCM)
White- is the power for the light (i can manage this one)
Red- goes to the ignition switch
Black- ground (i got this one aswell)
I can figure out the white and black wires just fine. But which wire from the car can i hook up the green wire from the Tach? Also which wire from the car is a good wire for the red wire from the tach?
Thanks for any help!
Old Mar 29, 2013 | 01:18 AM
97WS6SCharged's Avatar
Black is the ground.
Red goes to a fused & switched power feed.
White goes to the dash light circuit.
The green wire should be connected to the tac output signal from the PCM (pin A13).
Old Mar 31, 2013 | 09:29 AM
96 TA's Avatar
Thanks 97WS6SCharged, Is there a picture of the pin A13 to where i need to make the connection with the green wire? I would need something of the same to for the ignition switch as well, I don't claim to know very much about wires so I nearly need to be spoon fed this kinda stuff. Thanks
Old Mar 31, 2013 | 09:47 AM
You can tap into the tach wire here.
You can run your power wire to a spare terminal in the fuse panel marked IGN.
Old Mar 31, 2013 | 11:13 AM
96 TA's Avatar
Perfect! That makes is so much easier for me, thanks Shoe!
Old Apr 29, 2013 | 11:00 PM
96 TA's Avatar
ok so i installed my auto meter tach at the white wire in terminal D as depicted in shbox's photo but when i started my car the tach reads WAY off. It reads 800rpm high at idle and at 3000rpm's it reads at 6k! what could be the problem?
Old Apr 29, 2013 | 11:45 PM
8cylinders>4's Avatar
Did you take the tach apart and flip the tiny switches to adjust it to read an 8 cylinder signal? usually autometer tachs can be used with 4, 6, and 8 cylinder engines but need to be adjusted for it.
Old Apr 29, 2013 | 11:51 PM
96 TA's Avatar
I have heard about that switch however I looked at my gauge and it appears to be a solid unit. How would I disassemble it?
mr28
Apr 20, 2016 05:44 PM
Moshbmx1
Feb 17, 2015 10:51 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
