Auto meter guage lighting. Where to hook up?
Old Aug 24, 2004 | 11:18 PM
CoUnTryMuZiCZ28's Avatar
I have a Boost Guage and a Fuel pressure guage, they both have light bulbs that need to be hooked up.. I want to connect them to the same switch that I turn on my lights with.. Where do I connect them? I dont want to pull the dash apart to connect them to the actual switch, where is another location that would work off the switch?
Nick
Old Aug 24, 2004 | 11:21 PM
Heatmaker's Avatar
Advanced Member
Re: Auto meter guage lighting. Where to hook up?
what gauges do you have?
and you can wire them into the HVAC thing... if I recal that's wired to your night lights
Old Aug 24, 2004 | 11:22 PM
Originally Posted by Heatmaker
what gyafes do you have?
What???
Old Aug 24, 2004 | 11:28 PM
Heatmaker's Avatar
Advanced Member
Sorry... I'm kind of drunk... I ment to say gauges...
I guess I shouldn't drink and type...
and I mean what series of gauges do you have.
Old Aug 24, 2004 | 11:33 PM
S.J.S.'s Avatar
piece of cake buddy. Where are you gonna mount it. If its on the pillar than just run the wires down and connect them together. Put a jump clip on the end, slide it behind the dash on the fuse box side and just attach it to the fuse ( I believe the acces one ). It will work with when you turn on the switch, dimmer and all. Sorry if I was at home I could send you a pic. I actually took a picture of the rig.
Ultra Lite... Where is the wiring for the HVAC guages? Could I just solder the wires to the back of the fuse box on the HVAC fuse??
Old Aug 24, 2004 | 11:34 PM
What do you mean attach it to the fuse?
When you get home could you send me a pic?
Old Aug 24, 2004 | 11:44 PM
Bawls's Avatar
I used the BROWN wire coming from the headlight switch. So the gauge lights only come on when your parking lights or headlights are on. Which is only when its dark, which is when you should only need them to come on.
Old Aug 24, 2004 | 11:45 PM
S.J.S.'s Avatar
yeah no prob if I remember . If not email me to remind me.
Old Aug 24, 2004 | 11:46 PM
How did you get to it?? I dont want to take the whole switch out..
Old Aug 24, 2004 | 11:49 PM
Bawls's Avatar
LoL I took the whole switch out. Just remove the gauge bezel (for the oem gauge cluster) the switch is attached to that, unsnap, run a lead wire from the BROWN wire on the headlight switch (soldered of course) and run it up the a pillar, splicing off to each gauge.
Damn i miss my gauges lol.
Old Aug 24, 2004 | 11:51 PM
Head light switch or dimmer switch?
Old Aug 24, 2004 | 11:56 PM
Bawls's Avatar
Headlight switch. ya know the **** with 3 positions.
Old Aug 24, 2004 | 11:58 PM
Heatmaker's Avatar
Advanced Member
There's a bunch of ways you can wire it in... but easiest way is to just pull the fuse box and tap into one of the wires.
Old Aug 25, 2004 | 12:00 AM
ok if i did it that way.. which wire do i tap into that would work with the guage lights?
