auto eprom in a 6 speed car????
Old Sep 11, 2006 | 10:24 AM
96zvert's Avatar
Is it possible to have an automatic eprom in a 6 speed car and still have it run? It is a 92 LT1 vette, and watching a scan of it, the computer is telling the car to idle at 650 rpm, which is correct for an automatic car, but mine is a 6 speed. I am having some weird idle issues and running rich issues and wonder if this might be ppart of the problem. I thought all 6 speed cars were programmed to idle at 800? I know my 96Z was set to 800.
Old Sep 11, 2006 | 10:33 AM
Hootiez28's Avatar
Re: auto eprom in a 6 speed car????
When an auto computer went in my 6 speed car.......... reverse was locked out and I could only go in 1st and 4th The lockouts are pcm controlled so don't do it
Old Sep 11, 2006 | 10:46 AM
FuryZ28's Avatar
Depends on the year. Not sure with OBD-I & OBD-II units, but the 93 Fbodies only needed a 6-speed chip from GM to replace the auto one...
Old Sep 11, 2006 | 10:58 AM
96zvert's Avatar
mine is obd1 and would be the same as a 93Z with the removable chip.
i am not looking to put an auto chip in my car, just wondering if it had one in it because the computer is programmed to idle at 650.
Old Sep 11, 2006 | 11:11 AM
Hootiez28's Avatar
Good point...... Do the 93s even have skip shift and reverse lockout???
Old Sep 11, 2006 | 12:17 PM
96zvert's Avatar
I actually had a guy load an auto program into my 96z and noticed the same problems that Hootiez28 had. however, the vette uses a ZF transmission which has a reverse lockout on the gearshfit lever, not in the transmission.
Old Sep 12, 2006 | 07:11 AM
96zvert's Avatar
Anyone else????
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
tds1213
Nov 27, 2014 12:55 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
