ATTN: Shoebox/others, Line lock Question.
Old Apr 28, 2004 | 07:08 PM
Ekof96Z28's Avatar
Hey man, I was directed to you for some brake line/fitting sizes.
Im about to install a Hurst Roll Control line lock on my 96 Z28.
What size are the fittings that go into the master cylinder and into the ABS unit?
Also... what size line should I run?
Anything else I should know for this install? never messed with brakes much more than pads and rotors before.
Thanks in advance, I appreciate any help you or anyone else can give.
-Eric
Old Apr 28, 2004 | 07:57 PM
Mike383LT1's Avatar
line lock
i dont think you can use the hurst line look i beleave the only line lock you can use that ive seen is the slp
Old Apr 28, 2004 | 08:01 PM
Ekof96Z28's Avatar
Why wouldnt the hurst line lock be useable?
All it is... is a solenoid that holds pressure in the brake lines. My auto teacher said it would work as long as I installed it between the ABS unit and the master cylinder.
Old Apr 28, 2004 | 08:04 PM
Mike383LT1's Avatar
line lock
from what ive heard you cant install it before the abs modual the slp has dual inlets and outlets hopefully someone will chime in with the right answer but i think im right
Old Apr 28, 2004 | 08:09 PM
1msfyter's Avatar
My SLP linelock has 1 inlet and 1 outlet. Plumbed between the master cyl res and ABS. I ve seen hurst linelocks on other Z's
Just gotta bend the lines to fit
Old Apr 28, 2004 | 08:15 PM
steve10's Avatar
Most line locks can be used...the differences between most are very small...mostly from an appearance standpoint and the name on it.
It would be more cost effective to purchase a kit over trying to put together the line lock itself...Some think it is less expensive to build one themselves...if one added up the actual costs, most would find they are spending quite a bit of time finding the parts, and building them.
there is a discussion located here
http://www.ls1tech.com/forums/showthread.php?t=163885
Hope this helps.
Steve
Mike383LT1's Avatar
line lock
your corect just went to thier web site sorry for the bad info
Old Apr 28, 2004 | 08:36 PM
Front brake pipes
Old Apr 29, 2004 | 02:51 PM
Ekof96Z28's Avatar
Thanks alot shoebox and everyone else, exactly what I needed.
Old Apr 25, 2005 | 11:36 PM
c0rey's Avatar
Re: ATTN: Shoebox/others, Line lock Question.
Hey do you have to use the switch that comes with the line lock or can you use a better looking switch?
Old Apr 26, 2005 | 12:05 AM
JBird33's Avatar
You can always use a different switch man, they all do the same thing.
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Pampered-Z
Apr 14, 2015 05:38 PM
rje
Sep 9, 2002 12:35 PM
