ATTN shoebox and lt1 experts
i still have the same problem overall with my car but i have narrowed it down to a more consistent problem....
before it would barely run at any time but after replacing MAP sensor, oxygen sensor, fuel pres. regulator, injectors...etc
it fires right up and runs very strong with no signs of miss or smoke at all for about 1 minute but after about 1 minute after every start, the engine races way up on its own for about 5 seconds and emits a large amount of black smoke then barely runs, then dies...(floods)
this happens every time you start the engine(after letting it set for a little while)
has anyone had the similar problem? please help
I had a similar problem with a bad engine coolant temp sensor. I would get into closed loop and the ECT had a problem and would register -40 degrees and the PCM would kick it back into open loop (after seeing the engine temp being incorrect) and add a whole bunch of fuel. Mine set a couple codes for intermittent ECT high voltage, ECT performance, ect. I would check codes first to see what you have. More than likely, there will be something stored in there.
Just my .02
Just my .02
the problem has been located !!!!!
the problem has been located!!!
i replaced the Engine Coolant Temperature sensor!!!! (one by the crank) and now the car runs perfect!!!!!
thanks guys for all your help
F'n1996Z28SS
Aug 23, 2023 11:19 PM
SMO Q
Feb 11, 2015 07:13 AM
