ARP Studs for Windage Tray
Old Mar 17, 2025 | 01:57 PM
SweetToothMcRib's Avatar
I’m doing a more budget friendly 383 build on my 94 Z28 and I’m looking into putting some good ARP *bolts* into the bottom end. I decided to go with the bolts instead of the studs because I heard you need an align bore if you decide to go with the studs (checkbook won’t allow for that), plus I’m not spinning the motor very high so the bolts should hold just fine. With that being said, I can’t seem to find anything for the windage tray, it looks like it all comes in just main stud kits but all I want are the ones just for the windage tray. I can’t find a main bolt kit that also includes the studs for windage tray, I’m just wondering if someone has any ideas that might help me out of this situation I’m in.
Thanks in advance
Old Mar 20, 2025 | 10:18 AM
Chimera96's Avatar
Re: ARP Studs for Windage Tray
Miloden for windage tray
Milodon 81150 Milodon Windage Tray Stud Kits | Summit Racing
Or re-use the stock ones. You just need to use a 1/8" washer under the tray to stand it off to clear the 383 crank.
camaro81
Aug 2, 2007 09:25 PM
93redlt1
Jun 26, 2005 02:39 PM
v7guy
Dec 4, 2004 12:13 AM
BOTTLEDZ28
3rd Gen / L98 Engine Tech
Dec 4, 2004 12:10 AM
ReptileZ28
Nov 7, 2003 09:53 AM
