ARP Main Studs for my LT1??? Which kit and part#?
I need to know the ARP Main Studs kit and part# to use with my 388 LT1 stroker. I need to make the 2-bolt as strong as possible without going 4-bolt. I heard the studs are the best for the job but I wanna keep the windage tray/oil baffle that is attached to the stock main bolts. So???
Re: ARP Main Studs for my LT1??? Which kit and part#?
ok I know this is an old thread..but are those really good? I plan on keeping my stock crank with forged rods/pistons and running 14psi on a turbo...are these good enough?(234-5501)
14PSI on a stock 2 bolt bottom end with stock crank?????
Ya better loosen the clearances a bunch. The crank is gonna look like a rubber band when she is under boost.
If ya don't rattle it it may last a while and the ARP's will hold it IF the CAPS and CRANK AND RODS and PISTONS can.
