ARP Head bolts question
Old May 23, 2008 | 11:44 PM
Jazsun's Avatar
I know the ARP bolts have the washer which needs to go on. The washer is indented on one side. Which way does the indention go? Should the indention be facing the nut or be facing the block?
Old May 24, 2008 | 07:16 AM
94zgreenmachine's Avatar
By indented do you mean a chamfer on the inside diameter of the washer? Look at the underside of the bolt head. Is there a radius on the underside of the head to shank, on the bolt?
Old May 24, 2008 | 10:00 AM
Jazsun's Avatar
Yes there is a chamfer on the inside diameter. I though that would face the bolt head but some of the ones I got have it reversed...bought them used. So I was confused.
Old May 24, 2008 | 12:41 PM
OBE1 95Z28's Avatar
Chamfer needs to mate with the radius under the head of the bolt. The last guy probably didn't pay attention.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
