ARP Head Bolts
Old Mar 23, 2010 | 02:06 PM
RallyBoy1's Avatar
ARP Head Bolts
Well, I blew a head gasket sunday and I am looking to fix the issue myself. Can I re-use my current arp head bolts that are on the car already? I know they are not torque to yield like the factory bolts. Any advice is greatly appreciated. I have never done anything this major to my vehicle. I think the most difficult thing that I have done is change the fuel pump and intake manifold gasket. Hopefully it isn't too challenging.
Old Mar 23, 2010 | 06:23 PM
Revolutionary's Avatar
yep, apply some sealant (rtv, hylomar, liquid teflon etc) to the threads and go for it.
Old Mar 23, 2010 | 07:22 PM
ACE1252's Avatar
Clean the head bolt holes with a thread chaser(not at TAP!!!). I recommend sealing the head bolts with Permatex High temperature thread sealant.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Also clean the heads and block as best you can without gouging the surfaces. I start with a putty scraper for the heavy stuff and move to a razor for the difficult stuff....just be very careful. A steel razor to aluminum heads is generally a no-no. I've took a razor to aluminum and done okay, but again....be very careful.
Brake cleaner and lacquer thinner can help get surfaces clean too....lol, just don't smoke around it.
Old Mar 31, 2010 | 08:08 PM
my1994z28's Avatar
Yes you can re-use the ARP bolts,just make sure they are clean,use some sort-of sealant on the threads and torque to 65-70 ft lbs.
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
