arcing wire question
Old Jul 28, 2007 | 11:25 PM
ROUDA's Avatar
I put taylor wires in and it seems that my car shakes a little, the same way before it did when I had the stock wires what does an arcing wire feel like. This is what I noticed on the high way doing about 55mph pulls a little when it shakes what do you think. Ever since the headers I cant seem to get it running right.
Old Jul 28, 2007 | 11:49 PM
mrmint69's Avatar
Check for leaks, loose wires, broken sensors from the install, burnt plug wires & you might want to put an lt4 knock module in.
Old Jul 29, 2007 | 12:03 AM
mannycamaro's Avatar
From: San Juan Puerto Rico, Look it up it's in the Caribean
I have the same problem with Taylor Pro wires I by new plugs from summit and installed then the car shakes more. When I check all the cylinders one was missing, so I put the old cable in that cylinder and the problem was fixed.
One of the new cables was defective
Old Jul 29, 2007 | 12:52 AM
ROUDA's Avatar
I put new plugs in to I dont think any sensors are broke how do I check to see if its running on all cylinders.
Old Jul 29, 2007 | 12:53 AM
ROUDA's Avatar
And the lt4 knock module I will have to research it because I dont know anything about it.
Old Jul 29, 2007 | 01:11 AM
take out the cables one at the time with then engine running and if the car start to miss more that cylinder its ok ... In my car the cylinder missing was # 5
Also I have hookers headers and the are to close to the headers.
Old Jul 29, 2007 | 01:24 AM
Vamp's Avatar
I had the same problem after I did my headers. Chances are that...
1 Burned a wire, many people think they are fine and don't check this first for some reason.
2 Getting knock retard because of the exhaust, this was my problem along with 1 toasted wire. Knock won't really show up until you are driving and is hard to check to see if you have any. You will need a scanner or a laptop with the correct cable and software to check this.
If you are getting knock retard, then the LT4 knock module will/should help filter out the sounds causing it. I have one for sale on ebay right now and I explained what it does to the best of my ability on the page.
http://cgi.ebay.com/ebaymotors/ws/eB...148570939&rd=1
3 You o2 sensors are dead or dying. Headers with a coating will foul out the sensors after it burns off, requiring replacements. These are very important to how the car runs. Use only the o2 extenders, don't cut into the wires when extending them for the headers. I'm not sure if you had to do this or not...
4 Exhaust leak. Pretty easy to check, make sure your gaskets are sealing to the heads. Tighten down all of the bolts and listen for almost like a whistling noise. You can also put your hand down there and feel for any exhaust gases getting out.
Good luck finding the issue, if you just put in wires make sure they are routed away from the headers with zip-ties or the like. It's the most common problem after installing headers I think.
Old Jul 29, 2007 | 01:53 AM
SS RRR's Avatar
It's possible you have a missfire/dead cylinder. You'll have to carefully check the wires to make sure they aren't burnt. Happens all the time when people install new wires.
Old Jul 29, 2007 | 11:14 AM
ROUDA's Avatar
ok thanks Ill check it carefully.
Old Jul 29, 2007 | 12:31 PM
ROUDA's Avatar
It seems that it shakes harder sometimes just during idle so I dont know what it could be. I sounds like the valves are alot louder now to motor just maks alot more noise.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
